cwiebe
Sep 13, 2013Aspirant
Invalid Certificate.
I have a ReadyNas Duo V2 accessed with FF v23 on Win7 x64. When the nas was first installed, it was given an ip address of 192.168.0.157. Standards are devices get addresses below 120 so it was stati...
vandermerwe
Sep 14, 2013Master
vandermerwe wrote: I think you find the https settings in Configure, System, Services, https.
Once you've done this make sure you clear your browser cache.
You may need an OS reinstall as well if the above doesn't work.
You do it from readynas:
Go to Configure, System, Services. Then I think right click on https (it should already be activated). You should then see something that allows you to verify/change the ip address of the nas for the certificate, and something to regenerate it. This is the way it works in all of the other readynas operating systems so i assume it will be the same for 5.3.8
- May 04, 2020Retired_Member
