camalexander
Oct 21, 2010Aspirant
iPhoto '11 TROUBLE
My problems started when I launched iPhoto '11 for the first time. I received the warning "The library could not be opened because the file system of the library's volume is unsupported." I ha...
camalexander
Oct 22, 2010Aspirant
Thank you so much for your quick reply. I will definitely take your advice when setting up iPhoto again. iPhoto '09 did seem to work great on the NAS, I guess that was, until yesterday.
As for getting my share back working, any thoughts? I still get the warning:
"The operation can’t be completed because the original item for “iPhotos-NAS” can’t be found."
When I try to open it. I am created a dummy share to try to mimic the same problem and found that it occurred when I disabled CIFS and then tried to change the default to Read/Write.
So I am at a loss. I took some time to try and find the solution on the forum before starting this topic and I could not find anything that could help.
Thanks again for the quick response.
