camalexander
Oct 21, 2010Aspirant
iPhoto '11 TROUBLE
My problems started when I launched iPhoto '11 for the first time. I received the warning "The library could not be opened because the file system of the library's volume is unsupported." I ha...
sphardy1
Oct 23, 2010Apprentice
Hi Frank
If you could, that would be great - I've tested this over to other OSX clients and also had significant trouble, but I don't have access to a server install and was working under the assumption it would work based on some searches that suggested so. However, if you are right it would be very good to know & I'll gladly correct my post
Plus it would suggest Netgear are pretty much prevented from doing anything at all about this except developing a Direct Attached Storage device with HFS+ support so as to avoid the networking protocols.
