camalexander
Oct 21, 2010Aspirant
iPhoto '11 TROUBLE
My problems started when I launched iPhoto '11 for the first time. I received the warning "The library could not be opened because the file system of the library's volume is unsupported." I ha...
franklahm
Oct 23, 2010Aspirant
sphardy wrote: Frank - as soon as you get an iPhoto of any reasonalble size, iPhoto performance over AFP dies to the point of being useless. This is both over netatalk and to another mac even on a wired GbE connection.
My iPhoto Lib is 12 GB big and resides on an AFP volume. It's not ta snappy, but perfectly usable. More importantly this makes up a different issue than what the OP describes.
sphardy wrote: Therefore I expect the OP's problem would be very much the same via CIFS or AFP.
No it's not the same. CIFS gave him "not supported" because probably iPhoto 11 indeed checks if the Lib resided on a smb-vfs volume. He had an entirely different error with AFP.
sphardy wrote: Aperture has exactly the same issue.
Afair we've got a large customer using Aperture across AFP with huge asset stores just fine. So at least it depends. As always, network packet and syscall traces tell the truth.
sphardy wrote: Therefore, I will not be suprised in the least if iPhoto '11 network support is effectively worse than iPhoto '09
But if you have someway we can do this, please let us know.
As said, my iPhoto 11 Lib is usable just fine over AFP, iTunes too.
-f
