camalexander
Oct 21, 2010Aspirant
iPhoto '11 TROUBLE
My problems started when I launched iPhoto '11 for the first time. I received the warning "The library could not be opened because the file system of the library's volume is unsupported." I ha...
sphardy1
Oct 26, 2010Apprentice
camalexander wrote: When I open the NAS server window in Finder and double click on the iPhoto Share I get this message:
"The operation can’t be completed because the original item for “iPhoto-NAS” can’t be found."
When I go to Frontview the share is there and all looks good.
For this type of issue, if you are not comfortable with commandline access, then there is little that can be done to investigate. I would recommend you contact Tech Support so they may have a look.
@toad - How acceptable performance is will be subjective and related to the functions you are using - if you are happy that is all that matters
