dbrgzd
Sep 21, 2017Aspirant
Is firmware update necessary for ReadyNAS RN104?
We have this RN104 with firmware version 6.2.5. I understand that this is an old firmware but I'm unsure if updating would be important or just a risk (as I've seen some posts about updating bricked ...
- Sep 21, 2017
If it were mine, I would upgrade it. There have been quite a few fixes, including many security patches. Netgear would undoubtly require you to upgrade if you ever needed Netgear support.
On the other hand, if your NAS is well isolated from the internet, then the risk of those security issues affecting you is relatively small.
Upgrading would be a multi-step process (unfortunately Netgear dropped that information in the 6.8.0 release notes, but it is non-the-less correct). You'd need to update to 6.2.5, then to 6.5.2 and then onto 6.8.x. There is some risk that you'd run into trouble and need to do a USB recovery.
Sep 21, 2017Guru - Experienced User
- mdgm-ntgrSep 21, 2017NETGEAR Employee Retired
To do the update from 6.2.5 to 6.5.2 follow ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
Subsequent updates (e.g. 6.5.2 to 6.8.x) can be done the normal ways.
