ZapMePlease
Jun 10, 2016Aspirant
Is it safe to upgrade Apache?
I have an older ReadyNAS NV+. I'm trying to move my personal web server onto it. I've got the service running and it all works fine but I'm trying to password protect some pages. SO... I've ...
Retired_Member
Jun 10, 2016I understood that bit, but that's possible on OS4.2, natively. I'm accessing a share via HTTP and need to enter username & password.
It's not possible on OS4.1?
I'll habe to double check that as I don't remember.
Jun 10, 2016Guru - Experienced User
Yes, OS 4.1 also works that way. http://nasname/sharename will give you a user/password prompt.
