Forage
Aug 06, 2015Apprentice
Is it safe to use apt-get?
It's been quite a while since I've used the forum but man, what an cluttered unclear mess has it become... Who came up with the idea to switch to such an new forum? Was you drunk or high? Anyway....
mdgm-ntgr
Aug 07, 2015NETGEAR Employee Retired
Don't do an apt-get upgrade. That will break things.
There is a Python add-on: https://rnxtras.com/addons/python-2-7-readynas-5-arm
- ForageAug 08, 2015Apprentice
Yeah, I found the add-on, but I could use python-pip as well to be able to install aditional modules. I expect problems, like dependencies, if I install Python by means of an addon and python-pip through apt-get.
Does you suggesting to use the add-on also mean you advice against using apt-get to install just python?
- StephenBAug 08, 2015Guru - Experienced User
The specific advice is not to use apt-get upgrade
- mdgm-ntgrAug 09, 2015NETGEAR Employee Retired
I mentioned the add-on in case it did all you wanted.
You can certainly try installing what you need via apt-get but do make sure you have a good backup of your data first. If something goes wrong, you may end up needing to do a factory default (wipes all data, settings, everything) to get a working system again.An apt-get upgrade will update packages that we have deliberately held back on old versions and will break things. So definitely don't try that.
