mlbiss's avatar
mlbiss
Is there an upgrade/replacement path for Ready NAS 102?
I'm not sure I've done these tags right ... I bought my unit in 2014 and I believe the warrenty expired last August.  In November, I needed to get a new drive.  The process was slow but effective! ...
  • StephenB's avatar
    May 18, 2018
    bedlam1 wrote:
    This may be simple to resolve by just replacing the Power Supply Unit, it sounds as if your current one is failing
    A "risk buy" of a compatible power brick is worth a shot.  If you google AD8180LF 332-10318-01 you will find several inexpensive options.
    If that fails, then the RN212 is the currently shipping entry-level home NAS - faster and with more memory.   You can directly migrate your disks to the new unit.
ProSupport for Business
