Homith
Jun 07, 2020Guide
iSCSI and Network Bonding
Good Evening Everyone, Just wanted to reach out to the guru's here as I am stumpped at the moment. I have a ReadyNas 314 connected to a TP-LInk TL-SG108E switch. This switch supports the provision o...
- Jun 09, 2020
Good News Everyone,
I have figured it out !! (I am pretty excited!). The issue seemed to be with the iSCSI setup on the ReadyNas. I went into the iSCSI settings and within the properties of the group the 'Dedicated Link' was set to 'Any'. Changing this to "bond0:x.x.x.x" completely solved the problem.
In answer to your question acwdc, my SMB settings were as follows; Enable SMB (checked), Legacy Windows Discovery (checked), SMB3 Transport Encryption (Configured Globally - Enabled).
Hope this helps someone else out there. I really appreciate everyones help with this - a big thank you !!
Kind of wondered what would be the difference between ANY and the dedicated bond ID. Anyhow, it world now :)
Cheers,John
Homith
Jun 07, 2020Guide
Good Morning StephenB,
Thank you so much for responding to my query. I do appriciaite your time. The reasons for wanting to implement bondingn on the ReadyNas is to provide some sort of fault tollerance in addition to load sharing.
I have several other computers on the same network all connecting the ReadyNas using their own iSCSI and the network neighbourhood and was attempting to just add a little extra load balancing.
I am connecting to the ReadyNas via the iSCSI initiator via IP address.
Cheers and thanks for the advice
Jun 07, 2020Guru - Experienced User
You could try round-robin and see if that behaves any differently.
Are you seeing the issue only with iSCSI, or are you also unable to access Network Shares?
