Homith
Jun 07, 2020Guide
iSCSI and Network Bonding
Good Evening Everyone, Just wanted to reach out to the guru's here as I am stumpped at the moment. I have a ReadyNas 314 connected to a TP-LInk TL-SG108E switch. This switch supports the provision o...
- Jun 09, 2020
Good News Everyone,
I have figured it out !! (I am pretty excited!). The issue seemed to be with the iSCSI setup on the ReadyNas. I went into the iSCSI settings and within the properties of the group the 'Dedicated Link' was set to 'Any'. Changing this to "bond0:x.x.x.x" completely solved the problem.
In answer to your question acwdc, my SMB settings were as follows; Enable SMB (checked), Legacy Windows Discovery (checked), SMB3 Transport Encryption (Configured Globally - Enabled).
Hope this helps someone else out there. I really appreciate everyones help with this - a big thank you !!
Kind of wondered what would be the difference between ANY and the dedicated bond ID. Anyhow, it world now :)
Cheers,John
Homith
Jun 08, 2020Guide
G'day Acwdc,
Thanks so much for your reply on this - I do appreciate it. The issue I am confronted with is more to the fact that I can configure LAG on the switch, and set up the ReadyNas to a new bond (XOR/Lv2) and can still receive a ping response from the ReadyNas. I can selectivly disconnect one ethernet port at a time and the ping is constant.
The issue I am facing is that the Windows iSCSI Initiator can no longer reconnect to the target on the ReadyNas and the ReadNas is no longer visable within the Network Neighborhood. Very odd as the ping is constant.
Driving me batty hehe :)
Cheers
acwdc
Jun 08, 2020Aspirant
Homith,
Then, I do not thing you got issues with LAGs. Works on different network layer. I think its got to do with the SMB Master Browser. Have you have Legacy Windows Discovery enabled under the SMB settings of the NAS (i.e. SMB1)? Are all hosts local in your network?
AC
- HomithJun 09, 2020Guide
Good News Everyone,
Cheers,John
- acwdcJun 09, 2020Aspirant
Congrats Homith, nice find!
AC
