Homith's avatar
Homith
Guide
Jun 07, 2020
iSCSI and Network Bonding
Good Evening Everyone, Just wanted to reach out to the guru's here as I am stumpped at the moment. I have a ReadyNas 314 connected to a TP-LInk TL-SG108E switch. This switch supports the provision o...
  • Homith's avatar
    Homith
    Jun 09, 2020
    Good News Everyone,
    I have figured it out !! (I am pretty excited!). The issue seemed to be with the iSCSI setup on the ReadyNas. I went into the iSCSI settings and within the properties of the group the 'Dedicated Link' was set to 'Any'. Changing this to "bond0:x.x.x.x" completely solved the problem.
    In answer to your question acwdc, my SMB settings were as follows; Enable SMB (checked), Legacy Windows Discovery (checked), SMB3 Transport Encryption (Configured Globally - Enabled).
    Hope this helps someone else out there. I really appreciate everyones help with this - a big thank you !!
    Kind of wondered what would be the difference between ANY and the dedicated bond ID. Anyhow, it world now :)
    Cheers,
    John
ProSupport for Business
