llevon
Apr 19, 2011Aspirant
iSCSI Authorization failure
We purchased a Readynas 3100 of 8TB (5.5 TB usable storage) to use in an ESX environment of 4 ESXi servers and 25 VMs. (mainly linux, but a couple of windows servers as well.) -I created 1 iSCSI t...
Grievous
Apr 20, 2011Aspirant
Yes, you need to add the IQN of every initiator that will be connecting. it is required for the iSCSI daemon on the ReadyNAS to use the persistent reservations needed to maintain multiple connections otherwise it'll just keep kicking the first client off once the second connects.
