Xatosch
May 27, 2016Apprentice
iSCSI LUN Block Size
Hello... I have asked this question already in the german part of this community, but got no answer... On the ReadyDATA it is possible to adjust the block size, so host and client can use the...
- May 27, 2016
We currently use 512b for the block size. Currently there is no option to change this in the UI, but it would make an excellent feature request.
mdgm-ntgr
May 27, 2016NETGEAR Employee Retired
- XatoschMay 27, 2016Apprentice
Thank you for your answer. Good to know this, so I can adjust my NTFS to use the correct size :smileywink:
- mdgm-ntgrMay 28, 2016NETGEAR Employee Retired
You can make feature requests in Idea Exchnage for ReadyNAS Network Storage
- XatoschMay 28, 2016Apprentice
Yes, I could. But when I look at this group there are so many really good ideas, that are not implementet. I think this is a feature for the much more expensive ReadyDATA, and I'm pleased to know the used size...
I had made a test with my Steam-Library-Drive and the performance is recognizable faster, thats good!
