dannieboiz
Aug 27, 2014Tutor
ISCSI multiple clients
How come the contents made from one ISCSI client doesn't show in another client? I have a win 8 VM with my NVR records to the ISCSI but the recording doesn't show up when my server or any other cli...
TeknoJnky
Aug 27, 2014Hero
multiple iscsi client is like multiple computers trying read/write from the same hard drive simultaneously without each computer knowing what the other computers are doing.
each computer can accidently overwrite anything any other computer does = fubar data and/or filesystem
If you need to share data on an iscsi volume, then you should mount it in *one* computer, then *share* the applicable folder/files via that computer;
ie windows server > mount iscsi volume > share 'payroll' folder.
