gpearson9
Mar 11, 2017Aspirant
iSCSI not reconnecting - OS 6.6.1
I'm having a similar issue to both of these users who seemed to never get a resolution: https://community.netgear.com/t5/ReadyNAS-in-Business/iSCSi-won-t-reconnect/td-p/971430 https://community.net...
Skywalker
Mar 14, 2017NETGEAR Expert
This has been fixed in 6.7.0, which is available as a public beta release.
On 6.6.1, network reconnections are not noticed if you are using static IPs. So if you prefer a temporary workaround instead of updating to 6.7.0 beta, you can switch your ReadyNAS to use DHCP instead of static IPs.
gpearson9
Mar 14, 2017Aspirant
Good to hear, I will wait for the final release I think. Any estimate on when it might be available?
Just to be clear for your work-around, DHCP needs to be set on the network interfaces of the Netgear NAS, not the initiating clients?
