frolyar
Feb 14, 2017Aspirant
6.6.1 on ReadyNas 3200 iSCSI problem.
The problem is this: when I change any network settings (disable Ipv6, change LACP type l2 to l2+l3, etc) lost access to all iSCSI resources.
To return the access, need open iSCSI properties for each resources (lun in group), nothing to change and press "Apply".
This problem with any of the initiators: win 2008R2, RH5 or ESXI 5.5/6.0
How to fix it?
- JennCNETGEAR Employee Retired
- FramerVNETGEAR Employee Retired
Hi frolyar,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards, - frolyarAspirant
I'm install 6.7.0-T158 (Beta 1), problem not solved.
Hi frolyar,
So just to confirm, if you do not change any settings; it will be having no issues?
