frolyar
Feb 14, 2017Aspirant
6.6.1 on ReadyNas 3200 iSCSI problem.
The problem is this: when I change any network settings (disable Ipv6, change LACP type l2 to l2+l3, etc) lost access to all iSCSI resources. To return the access, need open iSCSI properties for ea...
- Feb 16, 2017
frolyar
Feb 26, 2017Aspirant
I'm install 6.7.0-T158 (Beta 1), problem not solved.
FramerV
Feb 28, 2017NETGEAR Employee Retired
Hi frolyar,
So just to confirm, if you do not change any settings; it will be having no issues?
