Alein
Feb 19, 2017Aspirant
ReadyNAS os 6.6.1 problem with snapshot
Hi, I have problems with FW:6.6.1
I saw in logs that snapshots are not created for one share. So I was trying to make manual one, and i get error
Code .28003020001
This share is compressed with SMB and RSYNC access.
Any ide what is wrong, what this error means?
that is what I did to solve it
snapper list-configs
Config | Subvolume
0 | /data/*-old/etc/snapper/configs
remove 0 (or copy it, number from the list)
reboot
after reboot
from web interface remove share, this time will go.
I am was not sure if this is fine, so
I recreate share from web interface
this time this share get nex number 5.
So, I remove share and I have a hope that this is it.
New snapshots are working fine.
- FramerVNETGEAR Employee Retired
Hi Alein,
I may need to inquire about the error code.
Just to isolate, when you try to manually create snapshot on a newly created shares; it works?
- AleinAspirant
Hi,
manual is not working, auto is not working.
For new share it is working fine with this same settings, and of course for all other shares.
I solve this problem creating new share. But I do not know if this problem will return or not, that is why I would like to know what this error means. It will takes some time until I will have full copy of my previous share ( it is almost 1TB of compressed data with 1M files, so I am copying files slowly without impact on production)
- JennCNETGEAR Employee Retired
- mdgm-ntgrNETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)? In your email please also mention which share you are having this problem on.
- Jun 06, 2017Retired_Member
