Alein
Feb 19, 2017Aspirant
ReadyNAS os 6.6.1 problem with snapshot
Hi, I have problems with FW:6.6.1 I saw in logs that snapshots are not created for one share. So I was trying to make manual one, and i get error Code .28003020001 This share is compr...
- Apr 03, 2017
that is what I did to solve it
snapper list-configs
Config | Subvolume
0 | /data/*-old/etc/snapper/configs
remove 0 (or copy it, number from the list)
reboot
after reboot
from web interface remove share, this time will go.
I am was not sure if this is fine, so
I recreate share from web interface
this time this share get nex number 5.
So, I remove share and I have a hope that this is it.
New snapshots are working fine.
FramerV
Feb 21, 2017NETGEAR Employee Retired
Hi Alein,
I may need to inquire about the error code.
Just to isolate, when you try to manually create snapshot on a newly created shares; it works?
- AleinFeb 23, 2017Aspirant
Hi,
manual is not working, auto is not working.
For new share it is working fine with this same settings, and of course for all other shares.
I solve this problem creating new share. But I do not know if this problem will return or not, that is why I would like to know what this error means. It will takes some time until I will have full copy of my previous share ( it is almost 1TB of compressed data with 1M files, so I am copying files slowly without impact on production)
- Jun 06, 2017Retired_Member
