Alein
Feb 19, 2017Aspirant
ReadyNAS os 6.6.1 problem with snapshot
Hi, I have problems with FW:6.6.1 I saw in logs that snapshots are not created for one share. So I was trying to make manual one, and i get error Code .28003020001 This share is compr...
- Apr 03, 2017
that is what I did to solve it
snapper list-configs
Config | Subvolume
0 | /data/*-old/etc/snapper/configs
remove 0 (or copy it, number from the list)
reboot
after reboot
from web interface remove share, this time will go.
I am was not sure if this is fine, so
I recreate share from web interface
this time this share get nex number 5.
So, I remove share and I have a hope that this is it.
New snapshots are working fine.
Alein
Feb 23, 2017Aspirant
Hi,
manual is not working, auto is not working.
For new share it is working fine with this same settings, and of course for all other shares.
I solve this problem creating new share. But I do not know if this problem will return or not, that is why I would like to know what this error means. It will takes some time until I will have full copy of my previous share ( it is almost 1TB of compressed data with 1M files, so I am copying files slowly without impact on production)
JennC
Feb 23, 2017NETGEAR Employee Retired
- AleinFeb 23, 2017Aspirant
Problem is, what this error means, not if I can or can not do something. You are posting your questions not answering my :)
- mdgm-ntgrFeb 23, 2017NETGEAR Employee Retired
Thanks for the logs. I've sent you a PM.
Seeing you're unable to provide remote access there's not much more I can do. That share is not setup properly to have snapshots on it. So my proposal was to remotely fix it.
- AleinFeb 24, 2017Aspirant
I can not allow you to access, due to nature of the data.
Please tell me what is wrong with this share, so next time I will fix it.
- Jun 06, 2017Retired_Member
