gpearson9
Mar 11, 2017Aspirant
iSCSI not reconnecting - OS 6.6.1
I'm having a similar issue to both of these users who seemed to never get a resolution: https://community.netgear.com/t5/ReadyNAS-in-Business/iSCSi-won-t-reconnect/td-p/971430 https://community.net...
gpearson9
Jun 05, 2017Aspirant
Well I found out the hard way tonight that this issue was absolutely not fixed in 6.7.0 (or 6.7.4 for that matter).
We had to restart our core switch over a configuration change, and as soon as we did all of our iSCSI devices started failing to log into the LUNs on the NAS... The same 'fix' as before worked, I went into the group for the LUNs and switched the Initiators option from 'Selected' to 'All', then back to 'Selected' and bam, all of the iSCSI devices re-connected immediately.
These devices simply cannot be used for iSCSI in this state... is there an actual fix planned soon??
mdgm-ntgr
Jun 06, 2017NETGEAR Employee Retired
Please send in a fresh set of logs (see the Sending Logs link in my sig).
- gpearson9Jun 06, 2017Aspirant
Thanks for the reply, I just sent an email with logs from the unit.
- SkywalkerJun 12, 2017NETGEAR Expert
The fix that went into 6.7.0 wasn't a complete fix. It only resolved the case where there was only a single static IP address. If you had multiple interfaces with different static IPs, only the first IP address would get reactivated for iSCSI. A complete fix will come in 6.7.5 Beta 2.
- gpearson9Jun 12, 2017Aspirant
That would make sense then, I am using static IPs on two of the interfaces on different subnets for MPIO. Thanks for the heads up! I wish I could use the DHCP work-around but our VLANs are completed isolated between the NAS and hosts so there is no way to assign an address unfortunately.
