mikemis
Dec 15, 2011Aspirant
iSCSI volume corrupted data
I have a ReadyNAS Ultra 6 with 6 3-TB drives in RAID 5 for a total of 16740 GB of usable space. I have configured one iSCSI target of size 13000 GB. I connect to the target with a Windows Server 200...
Grievous
Dec 19, 2011Aspirant
Unfortunately I'm not familiar enough with chkdsk to be able to answer that. I do know that chkdsk like most filesystem applications(such as fsck in linux) can take quite a while to run if there really is a problem. Now that you have it running, let it be. However I generally run them without having it automatically correct the errors first, then if it shows the errors and they're correctable, re-run it. Or check it with R-Studio like Jedi Knight suggested.
