sjk34
Sep 01, 2011Aspirant
Issue finding ISCI target with ReadyNAS DUO
Hi , im trying to set up an ISCI target it on my ReadyNAS DUO, I followed http://readynasfreeware.org/projects/nas-iscsi-target/wiki/New_Version and http://www.markwilson.co.uk/blog/2009/09/creating-a...
WhoCares_
Sep 01, 2011Mentor
If the Microsoft initiator doesn't find the target chances are it wasn't started properly. To verify you can check the system logs and see what the output of the iscsi target deamon ietd is. Also you should check the output of 'ps ax' and see whether the actual target deamon [istiod1] is running. You should see multiple instances of it.
-Stefan
-Stefan
