Awais
Jan 12, 2016Aspirant
Issue with Domain permissions
Hi, I have netgear readynas 314 and i have a problem to set domain level permissions. Before access was setup for everyone and now i want to setup for induvisual users. To resove the issue i have...
- Jan 12, 2016
Rather than "latest firmware" it is helpful for us to be provided the actual firmware version number.
You may need to try resetting the permissions on the share then configuring them following this guide: ReadyNAS OS 6: Setting Active Directory folder permissions
mdgm-ntgr
Jan 12, 2016NETGEAR Employee Retired
Awais
Jan 13, 2016Aspirant
Hi,
Thanks for the advice, i have set the permission via explorer as mentioned in the article but but now insisde the shared folder each file is read only and not allowing to edit anything. additionally if you create any folder or file inside the same folder it is alloswing to delete and edit.
Please advice on above.
appricate your help.
Thanks,
