Paulreid83
Dec 10, 2016Aspirant
Issues with Couchpotato install
Hi Im currently haveing an issue with couchpotato having used couch potato in the past, i noticed there was a new version realeased. i installed this from available apps which installed but wouldnt start when clicked on, i tried to delete this to reinstall and it did not uninstall correctly, i then had a look for files using explorer on the pc and deleted the files left over in the apps folder which removed the app. However i am now trying to reinstall couchpotato and the system is telling me it has installed correctly but it doesnot show in the installed app section of my admin pages, can any one help as i really am just a noob?
- evan2NETGEAR Expert
Hi Paulreid83 ,
Which FW version is installed your NAS?
- Paulreid83Aspirant
Hi its 6.6.0,is that any good?
- FramerVNETGEAR Employee Retired
Hi Paulreid83,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Hi Paulreid83,
Regards, - FramerVNETGEAR Employee Retired
Hi Paulreid83,
Welcome to the community.
Its possible that its needed to be removed from the back-end. This would need assistance from our engineers and/or higher tier support for remote access.
Please try to call our support group for warranty check. If are already out of warranty please consider getting a contract for the ReadyNAS.
