ianren
Aug 16, 2012Aspirant
Issues with Upgrade of Hard Drives
I am a relative novice and having difficulty upgrading a ReadyNAS Duo v1 from 500GB to 2TB. The new drives are referred to in the compatibility list, and I have successfully performed similar with an...
Aug 16, 2012Guru - Experienced User
The drive could have failed on the second resync. Can you test it on your PC with vendor diags?
