ianren
Aug 16, 2012Aspirant
Issues with Upgrade of Hard Drives
I am a relative novice and having difficulty upgrading a ReadyNAS Duo v1 from 500GB to 2TB. The new drives are referred to in the compatibility list, and I have successfully performed similar with an...
mdgm-ntgr
Aug 16, 2012NETGEAR Employee Retired
While failing to initialise would indicate a problem with the drive, there is software that vendors provide to test their disks which is what Stephen was referring to: http://www.readynas.com/kb/faq/hardware/how_can_i_verify_that_my_disk_is_bad
