ianren
Aug 16, 2012Aspirant
Issues with Upgrade of Hard Drives
I am a relative novice and having difficulty upgrading a ReadyNAS Duo v1 from 500GB to 2TB. The new drives are referred to in the compatibility list, and I have successfully performed similar with an...
Aug 17, 2012Guru - Experienced User
Also, since the drive is new, you can probably exchange it through the reseller. That is better than going back to the manufacturer, since the manufacturer will almost always replace it with a refurbished drive, not a new one.
