lospecht
Oct 30, 2016Guide
Itunes DVD artwork and NAS 314
My iTunes home videos (legally ripped DVDs) are mostly stored on my READY NAS 314 device. I can play them just fine in iTunes on my Mac from the NAS. However, when I go to set the DVD artwork using...
Oct 30, 2016Guru - Experienced User
lospecht wrote:
I tried turning on iTunes under Network Access but it did not seem to do anything so I turned it back off.
The NAS has a built-in linux iTunes server. If you'd left it on, you could have accessed the NAS-hosted itunes library from the iTunes on the Mac. The linux itunes server is reverse-engineered open source, and doesn't support home sharing - which limits its value. But it can be handy if you are playing the music from multiple Macs, and want to have only one iTunes library.
Anyway, it's fine to keep it off.
lospecht wrote:
However, when I go to set the DVD artwork using Get Info in iTunes and pointing to a .jpg in a sub folder of the movie folder on the NAS, the image does not get saved in the movie file.
Two things to try -
(a) can you change some other element in the tag? If you can, then iTunes can write to the ripped mp4.
(b) Does copying the jpg to your Mac, and applying the local copy as the artwork work?
- lospechtNov 07, 2016Guide
What I did before seeing your reply was to copy all the movie files off the NAS to an external HDD. That allowed me to insert the dvd covers. Then copy them back to the NAS. It's a hack but got the job done.
- FramerVNov 07, 2016NETGEAR Employee Retired
Hi lospecht,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
