XtheUnknown
Feb 24, 2016Apprentice
iTunes service does not start
When I click to enable the iTunes server on System/Settings/Services, it seems to start briefly (i.e. have green underline), and then stop again. Nothing on the log page to indicate an error. No ...
- Feb 27, 2016
Please check if the iTunes service is now working.
Your iTunes service config file was blank so I copied the default config across the re-enabled the iTunes service on the iTunes share.
JennC
Feb 24, 2016NETGEAR Employee Retired
Hello XtheUnknown,
Have you tried on another web browser? Or even enabling another service like ReadyDLNA?
How about reboot then try again?
XtheUnknown
Feb 25, 2016Apprentice
Tested using the latest versions of Firefox and IE.
ReadyDLNA is already enabled.
I have rebooted innumerable times.
Any other ideas?
- JennCFeb 25, 2016NETGEAR Employee Retired
Hello XtheUnknown,
This can be fixed from the backend, I think. Let's see if someone here from the community can do that.
- mdgm-ntgrFeb 25, 2016NETGEAR Employee Retired
Please send me your logs (see the Sending Logs link in my sig)
I have just sent you a PM.- XtheUnknownFeb 26, 2016Apprentice
Hi mdgm - log file sent as described...
- mdgm-ntgrFeb 26, 2016NETGEAR Employee Retired
Thanks for the logs. I see this in the logs for the iTunes Service
[FATAL] config: No directories specified for library[FATAL] main: Config file errors; please fix your configYou need to enable iTunes for a share. See Using ReadyNAS OS 6 and iTunes Service on Mac OS X
