russmoore07
Apr 08, 2015Aspirant
iTunes stuttering and stopping
I think I posted this in the wrong place the first time. --- I have NAS 314 with 3 matching WD 4TB drives in there. I am running 6.2.3 beta firmware. iTunes ver 12.1 (latest). Mac Mini (less than a...
Jun 03, 2015Guru - Experienced User
For standard ethernet, the MTU should be 1500.
Are you using the itunes server on the duo? Or is the itunes server/library on the iMac (with the media on the duo)? Is the iMac also using ethernet, or is it connected with wifi?
BTW, your profile says duo v2, but you have a v1.
