russmoore07
Apr 08, 2015Aspirant
iTunes stuttering and stopping
I think I posted this in the wrong place the first time. --- I have NAS 314 with 3 matching WD 4TB drives in there. I am running 6.2.3 beta firmware. iTunes ver 12.1 (latest). Mac Mini (less than a...
mdgm-ntgr
Jun 03, 2015NETGEAR Employee Retired
cruisingyacht wrote:
On another OT matter, as you note, I am using a v1 duo with 2 x 1TB in a RAID 1 config, which is overdue for replacement. I'd also like to replace the disks with WD Red or similar. What is my best upgrade path? (NAS first, then disks or vica versa? Do I simply replace one disk, initiate a disk mirror update, then replace the other disk etc) Or should I post this question in another forum?
New NAS with new disks. Use backup jobs to copy the data across from the old NAS to the new one. The RAID format is different in the new NAS. So simply migrating your disks across is not an option.
