russmoore07
Apr 08, 2015Aspirant
iTunes stuttering and stopping
I think I posted this in the wrong place the first time. --- I have NAS 314 with 3 matching WD 4TB drives in there. I am running 6.2.3 beta firmware. iTunes ver 12.1 (latest). Mac Mini (less than a...
cruisingyacht
Jun 04, 2015Aspirant
Thanks for the advice. I haven't yet tried running iTunes with the database files (.itl, .xml etc) on the iMac internal drive, with only the media files on the NAS. Will this work? Is it advisable?
I'll also look at upgrading to an RN102 / WD Red setup as suggested. Are the WD Red drives the most cost-effective / performance way to go? Or are others using better drives?
Presumably then the Duo can go to Time Machine backup duties?
