nas102
Jan 11, 2015Aspirant
JBOD disk upgrade
hi, I would like to upgrade existing 1TB drive to 2TB drive. This drive is secondary drive on RN102 configured to JBOD. To save time, it is possible to do the following to transfer all data in ...
Jan 29, 2015Guru - Experienced User
Good advice.
AndreasKa wrote: If the cloning software you have does block level cloning and partition expansion then it might work but i'm not sure which software will support this type of partition.
Make sure you have a backup and then try it and see if the software even recognises the partition as something it can work with.
But I'm not seeing any real time savings. Making a backup, installing the new drive, and restoring the backup will probably be as fast (or faster) than backing up, cloning/expanding - and won't require the experimentation.
