darklight
Jan 03, 2014Aspirant
JBOD over multiple disks
I have a RN102 that has been running X-Raid on a single 2TB disk for a while, now I want to expand the storage. I don't need redundancy, so I switched the volume to Flex-RAID (JBOD), intending to add ...
vandermerwe
Mar 02, 2014Master
Between step 1 and step 2 you should delete the volume on disk 2 using the GUI first, before removing the disk"
I would also backup the data on disk 1 before you do this.
Although data should be preserved during the switch, I'd recommend having a backup before you do it.
