VascoOliveira
Mar 18, 2020Aspirant
JBOD Volume creation failed
I have a ReadyNas RN102, and up until now, it was running with a single 4TB NAS disk in X-RAID mode. A few days ago, i've bough a new 4TB NAS disk, and, as expected (and i have forgotten), being in ...
- Mar 19, 2020
You really shouldn't post log zip files publicly, so consider unsharing the zip.
Look in rn-expand.log
-- Logs begin at Sun 2020-03-15 15:57:40 GMT, end at Mon 2020-03-16 00:06:06 GMT. -- Mar 15 15:58:35 nas-35-A8-1B rn-expand[2336]: Creating pool: DISK2 Mar 15 15:58:35 nas-35-A8-1B rn-expand[2336]: * Level: 1 Mar 15 15:58:35 nas-35-A8-1B rn-expand[2336]: * Disks: Mar 15 15:58:35 nas-35-A8-1B rn-expand[2336]: 0:1 (sdb,ST4000VN008,3726GB) Mar 15 15:58:35 nas-35-A8-1B rn-expand[2336]: prepare_disk: Prepare disk 0:1 (sdb,ST4000VN008,3726GB) with partition size 7804599872 Mar 15 15:58:35 nas-35-A8-1B rn-expand[2336]: Found sdb is not a member of root Mar 15 15:58:42 nas-35-A8-1B rn-expand[2336]: Partitioning failed! [4] Mar 15 15:58:42 nas-35-A8-1B rn-expand[2336]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Warning! GPT main header not overwritten! Error is 5;Warning: The kernel is still using the old partition table.;The new table will be used at the next reboot or after you;run partprobe(8) or kpartx(8);GPT data structures destroyed! You may now partition the disk using fdisk or;other utilities.;Warning! MBR not overwritten! Error is 5!;Warning! Read error 5; strange be Mar 15 15:58:42 nas-35-A8-1B rn-expand[2336]: adding partition failed [5] Mar 15 15:58:42 nas-35-A8-1B rn-expand[2336]: Found sdb is not a member of swap Mar 15 15:58:43 nas-35-A8-1B rn-expand[2336]: Partitioning failed! [4] Mar 15 15:58:43 nas-35-A8-1B rn-expand[2336]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.; Mar 15 15:58:46 nas-35-A8-1B rn-expand[2336]: Partitioning failed! [4] Mar 15 15:58:46 nas-35-A8-1B rn-expand[2336]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.;
And disk errors in kernel.log
Mar 15 16:20:51 Multimedia kernel: ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 13 dma 4096 in res 51/04:08:00:00:00/00:00:00:00:00/e0 Emask 0x1 (device error) Mar 15 16:20:51 Multimedia kernel: ata2.00: status: { DRDY ERR } Mar 15 16:20:51 Multimedia kernel: ata2.00: error: { ABRT } Mar 15 16:20:51 Multimedia kernel: ata2.00: configured for UDMA/133 (device error ignored) Mar 15 16:20:51 Multimedia kernel: ata2: EH complete Mar 15 16:20:51 Multimedia kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Mar 15 16:20:51 Multimedia kernel: ata2.00: irq_stat 0x40000001 Mar 15 16:20:51 Multimedia kernel: ata2.00: failed command: READ DMA Mar 15 16:20:51 Multimedia kernel: ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 14 dma 4096 in res 51/04:08:00:00:00/00:00:00:00:00/e0 Emask 0x1 (device error) Mar 15 16:20:51 Multimedia kernel: ata2.00: status: { DRDY ERR } Mar 15 16:20:51 Multimedia kernel: ata2.00: error: { ABRT }I suggest testing this disk in a Windows PC with Seatools. Run the extended non-destructive test first. If that passes, then run the full erase test.
I don't expect it to pass both Seatools tests - I think this disk has failed. If this is a new disk, then try to exchange it with the seller - that will give you full warranty coverage on the replacement.
VascoOliveira
Mar 19, 2020Aspirant
Thank you for your response.
Its a new disk, do you have any guess on why a new disk has failed?
Mar 20, 2020Guru - Experienced User
VascoOliveira wrote:Its a new disk, do you have any guess on why a new disk has failed?
Sometimes they fail out-of-the-box (I've had a couple that have done that). That could be a manufacturing issue with that particular disk, or perhaps it was mishandled during shipment.
I always test mine before I install them into the NAS. You can do that by connecting it to a windows PC and running Seatools - running both the long non-destructive test and the full erase (write zeros) test. The write zeros test sometimes will uncover problems that the non-destructive test won't. Note you can either connect the disk using SATA or a USB adapter/dock.
