Lithium-Admin
Jun 23, 2012Novice
Jumbo Frame question (Duo v2) & Perf update (new router)
Hi Guys, Quick question. I used to own the Duo v1, where you can turn on/off jumbo frames. I don't see that on the latest firmware for Duo v2. Also, I can't find it anywhere on documentation in reg...
christopherw
Jun 26, 2012Aspirant
I'm not sure if the Duo v2 really needs to 'support' Jumbo frames, I get decent enough read and writes without it explicitly enable-able on the unit. (Just under 47 Mbps write speed, 58 Mbps read speed tested in iometer using the config file from the site.) Who knows? It may already implicitly support a 9000 MTU; given the unit's running X-RAID2 on an ARM CPU I'm pretty happy with these results.
(I have a Ultra 2 at home, throughput isn't much faster than this!)
- Sep 30, 2022Retired_Member
