Retired_Member's avatar
Retired_Member
Sep 29, 2022
XR500 Update Question
I have a question about updating on the xr500. Do I need to factory reset first before updating or update first then factory reset? Also What seems to be the most stable firmware right now?
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Oct 01, 2022
    It's been out for awhile so it's quite stable, if you aren't having any issues on your current version and you don't want to rock the boat then you could stay on your version. Just keep in mind you may not have the latest security fixes.
  • FURRYe38's avatar
    Afterwards.
    I recommend setting the DHCP default IP address pool size to .100 to .200 after you factory reset and setup from scratch.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    • Retired_Member's avatar
      Retired_Member
      I’m using the cm700 modem
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        OK sounds good, feel free to complete the steps FURRYe38 recommends and you should be good to go!
      Retired_Member
      Ok you still didn’t answer my 2nd question. Which firmware is most stable currently or what would you suggest? Don’t know why support is so hard to get around here.
      • FURRYe38's avatar
        Try what's currently loaded on the router, "if the router works, don't fix it."
