Lithium-Admin
Jun 23, 2012Novice
Jumbo Frame question (Duo v2) & Perf update (new router)
Hi Guys, Quick question. I used to own the Duo v1, where you can turn on/off jumbo frames. I don't see that on the latest firmware for Duo v2. Also, I can't find it anywhere on documentation in reg...
Lithium-Admin
Jun 26, 2012Novice
Well, to my understanding jumbo frames would help significantly to increase the write speeds and doesn't really affect the read speeds.
Correct me if I'm wrong, but if your getting 58 Mbps = 7.25 megabytes / second, that's 7.25 MB/s... isn't that a bit slow?
I'm getting above 100 MB/s read on my Duo v2 (100 MB/s = 800 Mbps). Pretty much maximizing my gigabit ethernet network at home (1 000 000 000 (bits per second) = 119.20929 MB/s).
- Sep 30, 2022Retired_Member
