bettley_smith
Sep 11, 2010Aspirant
Jumbo Frames Issue
Running readynas Pro, netgear GS716T ports configured for framesize 9216, PC also running jumbo frames but when I look at the diagnostic logs i see this: Disks ------------------------------- Pas...
mdgm-ntgr
Jan 08, 2012NETGEAR Employee Retired
SJB66 wrote:
I notice that you are using a Duo V2 !
Sure am (along with some other ReadyNAS models).
SJB66 wrote:
Is there any way to deal with the Jumbo Frames issue on this device when using dashboard 1.0.0.168 ?
You don't need to enable Jumbo Frames on your devices, in fact it's not an option in the dashboard. Jumbo Frames isn't enabled on the Duo v2
SJB66 wrote:
I have just recently purchased a DuoV2 and using it via a 2wire router modem I am having difficulty transferring bulk files without getting a false "device full" message.
So is Jumbo Frames enabled on your other devices? If not, then no Jumbo Frames isn't the problem. If you have, you could try SSHing in and editing /etc/network/interfaces, but this would be unsupported and the changes might not stick.
Btw this thread is very old. Please in future open a new thread rather than reviving an old thread. If necessary say something I like "I think my issue is like the one mentioned here: <INSERT URL>"
edit: Don't edit /etc/network/interfaces. Edit /etc/default/services. There is a line you can add that should enable jumbo frames: "JUMBO_FRAMES_eth0=0" (no quotes). An OS re-install should disable Jumbo Frames if this doesn't work.
