hengy1
Oct 18, 2014Tutor
Jumbo Frames Packet needs to be fragmented
I'm trying to set up jumbo frames. The Readynas NV is set to autonegotiation with an MTU size of 7936. I'm using a terminal and trying to access it to determine best MTU size for transmission. The hig...
mdgm-ntgr
Oct 19, 2014NETGEAR Employee Retired
There's also the possibility of a compatibility issue. You may find with a newer NAS that Jumbo Frames works fine where it doesn't with your NV.
You will certainly get a much bigger performance increase from getting a new ReadyNAS (even without Jumbo Frames) than getting Jumbo Frames to work with your NV.
- Aug 04, 2024Retired_Member
