hengy1
Oct 18, 2014Tutor
Jumbo Frames Packet needs to be fragmented
I'm trying to set up jumbo frames. The Readynas NV is set to autonegotiation with an MTU size of 7936. I'm using a terminal and trying to access it to determine best MTU size for transmission. The hig...
hengy1
Oct 19, 2014Tutor
You're absolutely right. A new NAS might work, might not. But this NAS has jumbo frames. Hopefully this doesn't meant that jumbo frames never worked correctly on the readynas nv. I do have a new netgear gs105 unmanaged switch between them. I am getting 80+ mb/sec between my main computer and another one on the same network which has a Dlink router in addition to the gs105 between them. So jumbo frames are indeed working correctly on the network.
- Aug 04, 2024Retired_Member
