hengy1
Oct 18, 2014Tutor
Jumbo Frames Packet needs to be fragmented
I'm trying to set up jumbo frames. The Readynas NV is set to autonegotiation with an MTU size of 7936. I'm using a terminal and trying to access it to determine best MTU size for transmission. The hig...
hengy1
Oct 19, 2014Tutor
Perfect, now I've got some good info. I'll be replacing this switch with one that does support jumbo frames. Thanks. One question though. Transfer rate between 2 pcs with gigabit ports is 80+mb/sec. Why wouldn't I get the same from the Readynas NV? I guess the pcs aren't using jumbo for that speed. Curious.
- Aug 04, 2024Retired_Member
