hengy1
Oct 18, 2014Tutor
Jumbo Frames Packet needs to be fragmented
I'm trying to set up jumbo frames. The Readynas NV is set to autonegotiation with an MTU size of 7936. I'm using a terminal and trying to access it to determine best MTU size for transmission. The hig...
Oct 19, 2014Guru - Experienced User
Because its an old design and is just not fast enough. The system maxes out around 25 MB/s.
hengy wrote: Why wouldn't I get the same from the Readynas NV?
Newer ReadyNAS deliver 50 to ~100 MB/s.
- Aug 04, 2024Retired_Member
