FrankB2
May 29, 2011Aspirant
jumbo frames slow things down
Hi, I have a pc with NIC capable of doing Jumbo Frames (9K). It´s connected to a netgear GS108. The label of the GS108 says GS108GE and has serialnumb 21620C3H0025A. On the netgear site it says th...
mdgm-ntgr
May 31, 2011NETGEAR Employee Retired
Do you have the latest NIC drives installed on your PC?
Could you try a direct-connection using a known working Cat5e or newer ethernet cable to eliminate the switch as the issue? See http://sphardy.com/web/readynas/how-to-direct-connect-to-your-readynas/
