FrankB2
May 29, 2011Aspirant
jumbo frames slow things down
Hi, I have a pc with NIC capable of doing Jumbo Frames (9K). It´s connected to a netgear GS108. The label of the GS108 says GS108GE and has serialnumb 21620C3H0025A. On the netgear site it says th...
Mahieu
Apr 28, 2013Aspirant
my mistake, yes, rather 15MB MAX w/o JF ;)
But...., as I was writing my previous coment, I changed something in my config and....... now I am stuck again at 15MB/s MAX
>>> Noooooooooooo :/
my config:
NV+: JF: on, MTU: 7936
Switch: Maximum Frame Size 7936
my PC (realtek Gig-E): JF on and max MTU : 7K (aslo tried 9K, no change).
between them: CAT3 cable (+/- cat6E / cat7, with a dedicated sat wire).
my transfers :
I send three files to my readynas simultaeously: 2,5MB by transfer....
simultaeously, I send another file to another NAS: 25MB (throughput has not changed for that NAS).
>> the problem should thus come from my readynas but I cannot understand/find the problem. this nas is really pissing me off........
>>> Noooooooooooo :/
my config:
my transfers :
