nrobinson1
Dec 10, 2015Aspirant
Kernal PAnic - how to turn NAS off?
I have got the message "Kernal Panic", after turning my ReadyNAS NV+ v1 back on, and have read the threads about checking disks etc. But I cannot do this until I have managed to turn the NAS off ...
- Dec 14, 2015
Hi nrobinson1,
You cannot update the firmware without disks inside the NAS. Since all four drives passed the extended test, you may insert all four drives and check if the NAS boots up just fine. Check if you can still access the data stored in it. Then observe, if the Kernel Panic message appears again.
Also, if you are able to access the data stored in your NAS, the first thing to do is to make sure to back up all of it right away for safety.
DaneA
NETGEAR Community Team
JennC
Dec 10, 2015NETGEAR Employee Retired
Hello nrobinson1,
I hope you have full backup of the data.
Do not remove disks yet. Please perform memory test from the boot menu.
- nrobinson1Dec 10, 2015Aspirant
How do i perform a memory test without rebooting so that I can hold the power button down for 25s to do memory test - hence the main question - how do I restart a NAS that wont power down?
Cheers,
Nik.
I have tried RAIDar 6.0 but it cannot see the NV+ only my Duo.
Cheers,
Nik,.
- StephenBDec 10, 2015Guru - Experienced User
You have duplicate threads going. I tried to kill this one, but that didn't happen.
As I replied here: https://community.netgear.com/t5/Using-your-ReadyNAS/Help-Kernel-Panic-How-to-turn-off/m-p/1016411#U1016411
At this point you need to risk pulling the plug.
