EcstaticBrick
Feb 05, 2019Aspirant
LAN Connection Help ReadyNAS 204
Hi, I hope this is the right place to ask. I need a little help a issue I am having with my local network.
I have a very unreliable internet connection. I can lose my connection 2-3 times a day...
EcstaticBrick
Everything is shared via NFS. Could that be a the issue
Feb 06, 2019Guru - Experienced User
I don't think so. Are your media players and the NAS both connected to the switch?
- EcstaticBrickFeb 06, 2019Aspirant
Yes. Everything is connected to the switch. Nothing is directly connected to my router
- StephenBFeb 06, 2019Guru - Experienced User
Try playing a movie, and then disconnect the cable between the router and the switch. Check if the movie continues to play or if it drops.
- EcstaticBrickFeb 12, 2019Aspirant
Hi, sorry for the late reply. Work keeps getting in the way.
Yes, Watching a movie and pulling the router from the switch causes a loss of connection to the nas.
