VarkGripper
Jun 08, 2017Aspirant
Latest Firmware 4.1.16
I ran the Firmware 4.1.16 that Netgar issed and followed the normal process and nwo I am unabel to gian acces to the Admin page. I can see the data and can view in in SSH but not in the Admin page an...
- Jun 09, 2017
Thanks for the help. Still no go and have decided to do a Factory re-set. The steps got very close and at one point it was send, me emails saying nothing or "Dead. This volume is no longer available. (VarkWork)"
Now rebuilding Raid. I will accept this as a solution.
Roger
VarkGripper
Used 114 GB
Free 807 GB.
I now have a RN202 with 2 TB space and only use the old one for testing and dev.
Jun 08, 2017Guru - Experienced User
VarkGripper wrote:
Used 114 GB
Free 807 GB.
No - that's the C volume. I asked for the OS partition - which is only 2 GB on that NAS.
SSH in, and enter
df . -h
df . -i
- VarkGripperJun 08, 2017Aspirant
Filesystem Size Used Avail Use% Mounted on
/dev/c/c 922G 115G 807G 13% /c
VarkWork:/Webroot/Sparc# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/c/c 30474240 65171 30409069 1% /c - VarkGripperJun 08, 2017Aspirant
- StephenBJun 08, 2017Guru - Experienced User
I think must have you cd'd somewhere else when you logged in with ssh. Try again, this time do a cd // first.
Now set at root of file system
VarkWork://# ls
backup bin c dev etc frontview home HU3A initrd lib lost+found media mnt opt proc ramfs root sbin sys tmp USB usr var Webroot
VarkWork://# df . -h
/dev/md0 1.9G 658M 1.2G 34% /
VarkWork://# df . -i
/dev/md0 128000 17066 110934 14% /
VarkWork://#
